Thread: Fan Blade Balancing?
24-08-2010, 04:46 AM #1
Has anyone ever had any success balancing a fan blade by bending the pitch of a blade or adding weight?
24-08-2010, 07:34 AM #2
Re: Fan Blade Balancing?
have manually bent blades before, but dont suggest it as a complete solution, doubt you would be successful adding wieghts, needs to be done by the right people with the right equipment, ie people that balance turbo shafts etc. thou this is reflective of the size of blade too be balanced. If it is a small blade like you would find on a 1/2hp condensing unit, in the past i have bent the blades to match there distance from the cowling surround, i was taught that the blade should sit 50/50 to the cowling
24-08-2010, 02:16 PM #3
hi roberzie, a very difficult job you got , first I would sugest drilling holes< on the heavy side< not adding weights , secondly the fan blade needs to sit on a shaft that can rotate on 2x2wheels so that it can spin , and then rest with the heavy part at the bottom, all the best , ballencing , sedgy
24-08-2010, 11:33 PM #4
What type of fan is it?
27-08-2010, 07:02 AM #5
Perfect balance ceiling fans need feature of self correcting, ceiling fan blade balancing system that constantly adjusts ceiling fan blades.
27-08-2010, 09:17 AM #6
why don't they invent selfregulating fanblades, like they use for schipspropellers?
Ice
Matching & Balancing between Evaporator and Compressor
By M.Saleh in forum Air ConditioningReplies: 3Last Post: 22-01-2010, 01:48 PM -
chilled water balancing
By tchc in forum IndustrialReplies: 1Last Post: 18-01-2010, 07:59 PM -
refrigeration systems balancing
By aashvac/r in forum TrainingReplies: 4Last Post: 26-05-2008, 09:09 PM -
Testing and Balancing Proceedures
By Tradewinds in forum Refrigeration BooksReplies: 4Last Post: 24-01-2008, 09:11 PM -
Component balancing & cross plots query.
By refca in forum FundamentalsReplies: 0Last Post: 21-11-2007, 11:49 AM
