Thread: York screw
24-08-2010, 03:23 PM #1
York screw
Hi Folks,
A new customer of ours has an old york screw on a glycol chiller usong r134a. We been asked if we can overhaul it but i am unsure if we can without buying the "correct" york tools to withdraw bearings etc - has anyone got any advice??? the model is a YCCH233SO333YF. Also does anyone know the bearing type in this unit so i can pre order ???
Ta
24-08-2010, 05:19 PM #2
Re: York screw
this model is based on Frick TDSH 283, it has fixed VI and some modification for using in York chillers
24-08-2010, 05:20 PM #3
Re: York screw
sorry TDSH 233
26-08-2010, 12:34 PM #4
Re: York screw
Could be worth contacting Sabroe in Denmark, they do these all the time
26-08-2010, 06:55 PM #5
Re: York screw
if you need, I can send to you bearing list for FRICK compressors
York Millenium Screw Chiller Code
By wint100 in forum Industrial CompressorsReplies: 8Last Post: 06-02-2011, 10:05 PM -
York Screw Model YCASO330
By James K. Donell in forum Technical SpeculationsReplies: 1Last Post: 12-06-2010, 11:24 PM -
YORK Rotary Screw Compressor
By xelazman in forum Industrial CompressorsReplies: 7Last Post: 28-04-2010, 08:37 PM -
York Screw Oil Problem
By tomt in forum Technical DiscussionsReplies: 10Last Post: 02-12-2009, 03:48 PM -
York Screw Chiller How low will it go?????
By bruceboldy in forum Industrial CompressorsReplies: 11Last Post: 10-08-2007, 10:29 PM
