Thread: Plastic pallets
    India
    688
    Plastic pallets
    We face a typical situation.
    The Pallets if to be used in Drive in Racking need a bracing on 1200mm side. Typical Pallet size is 1200 x 1000mm. The form entry is from 1200mm side.
    The bracing makes it difficult for the stacker to lift the pallet unless we use slave pallet on the ground. below this pallet.
    If anyone knows a company which can make 1200 x 1000mm pallet with no bracing on 1200mm side but can take a dynamic load of 1000 kgs if put in drive in racking rails?
    Oct 2006
    1,843
    21
    Re: Plastic pallets
    Quote Originally Posted by smpsmp45 View Post
    I think I know what you mean but to be sure put a photo up please.
    taz
    India
    688
    Re: Plastic pallets
    I am not sure if I can upload the file now.
    Attached Files Attached Files
    Oct 2006
    1,843
    21
    Re: Plastic pallets
    I would try these.
    http://www.chep.com/Home.aspx?lang=en-ZW
    I'm not sure if they do your pallet but they will know.
    All the best
    taz
    India
    688
    Re: Plastic pallets
    Many Thanks. I shall contact them,.
  1. plastic refrigeration fittings?
    By chillywilly in forum New Technologies
    Last Post: 14-11-2008, 02:46 PM
  2. Brown or Black plastic box trunking
    By alex242 in forum Air Conditioning
    Last Post: 07-05-2007, 10:06 AM
  3. Inner plastic doors
    By bernard in forum Supermarket Refrigeration
    Last Post: 01-07-2005, 10:20 PM
  4. Storage space between pallets
    By Peter_1 in forum Industrial
    Last Post: 24-01-2005, 07:38 PM
  5. Waterflow in plastic tube
    By Peter_1 in forum Technical Speculations
    Last Post: 23-04-2004, 01:09 AM
