    Feb 2009
    las vegas
    4
    Fan Blade Balancing?
    Has anyone ever had any success balancing a fan blade by bending the pitch of a blade or adding weight?
    cjay's Avatar
    cjay Guest
    Re: Fan Blade Balancing?
    have manually bent blades before, but dont suggest it as a complete solution, doubt you would be successful adding wieghts, needs to be done by the right people with the right equipment, ie people that balance turbo shafts etc. thou this is reflective of the size of blade too be balanced. If it is a small blade like you would find on a 1/2hp condensing unit, in the past i have bent the blades to match there distance from the cowling surround, i was taught that the blade should sit 50/50 to the cowling
    Oct 2008
    mallorca, spain,
    75
    768
    hi roberzie, a very difficult job you got , first I would sugest drilling holes< on the heavy side< not adding weights , secondly the fan blade needs to sit on a shaft that can rotate on 2x2wheels so that it can spin , and then rest with the heavy part at the bottom, all the best , ballencing , sedgy
    11,024
    What type of fan is it?
    Aug 2010
    US
    54
    8
    Perfect balance ceiling fans need feature of self correcting, ceiling fan blade balancing system that constantly adjusts ceiling fan blades.
    May 2008
    66
    802
    why don't they invent selfregulating fanblades, like they use for schipspropellers?
    Ice
  1. Matching & Balancing between Evaporator and Compressor
    By M.Saleh in forum Air Conditioning
    Last Post: 22-01-2010, 01:48 PM
  2. chilled water balancing
    By tchc in forum Industrial
    Last Post: 18-01-2010, 07:59 PM
  3. refrigeration systems balancing
    By aashvac/r in forum Training
    Last Post: 26-05-2008, 09:09 PM
  4. Testing and Balancing Proceedures
    By Tradewinds in forum Refrigeration Books
    Last Post: 24-01-2008, 09:11 PM
  5. Component balancing & cross plots query.
    By refca in forum Fundamentals
    Last Post: 21-11-2007, 11:49 AM
