    Jun 2005
    US
    63
    8
    GE UK Kit 2 Automatic Icemaker Installation Kit
    I searched all over the web and came up with out an answer, so I thought I'd try here.
    Is this kit (UK Kit 2) designed to replace the manual method of making ice cubes, or is a factory replacement unit, or both?
    Also is there a web-site where I could find a complete listing of what makes and model number refrigerators this kit will work with?
    Thanks in advance for your help,
    Rookie
    rbartlett's Avatar
    rbartlett Guest
    Re: GE UK Kit 2 Automatic Icemaker Installation Kit
    http://www.appliancepartsofamerica.com/icemakers.html
    it seems to be the old 1/2 moon shape ice maker..okay but can't produce clear ice.(the mark of a good icemaker??)
    low volumes only/low maintenance -usually it's the stat that fails-suitable for homes etc -most 'american type' refrigerators use this system
    cheers
    richard
    Sep 2003
    ISRAEL
    72
    4,248
    here is some answers from the WWW
    http://home.listings.ebay.com/Refrig...istingItemList
    Try Google, I'm sure you can find more.
    Chemi
  1. Used Equiptment installation Problem
    By PAXFREON in forum Legal-Business-Marketing
    Last Post: 23-04-2010, 10:36 PM
  2. LEC Icemaker
    By Andy AC in forum Commercial
    Last Post: 24-08-2009, 01:05 PM
  3. changing to automatic valve
    By donato in forum Technical Speculations
    Last Post: 29-07-2006, 12:50 PM
  4. Installation of cold room
    By Josip in forum Legal-Business-Marketing
    Last Post: 12-03-2006, 09:20 PM
  5. Equipment & Installation specifications
    By Kevin Yeo in forum Fundamentals
    Last Post: 14-01-2006, 10:36 AM
