Results 1 to 9 of 9
Thread: Flexible lines
    Scotland
    327
    Red face Flexible lines
    Hello
    Im am fitting a cold room on an articulated lorry trailer.
    I am running the pipes 3/8 and 1/4 in normal refrigration tube and want to use flexible lengths of about 1m for the final connections with a female flared connection at each end.
    Am I right in thinking these need to be purchased in coils and made to measure on site using a purpose built crimping tool of some kind?
    I wanted to buy something off the shelf but can't find anywhere.
    On a similar topic, does anyone know where I can buy nylon coated capillaries for coupling to pressure switches?
    I am not looking for vibration eliminators, the copper will be well supported, it's just the ends that will be flying.
    What about manifold lines?
    Thanks.
    11,025
    Re: Flexible lines
    Might be worth speaking to these people...
    http://www.ryanairconspares.com/racs...50c4127a569744
    I think I've seen the flexible capillaries in Climate Center, but I'm sure most suppliers do them.
    Oct 2003
    5,630
    34
    Re: Flexible lines
    This is exactly what we make a few times in a year.
    For the flexible lines for the pressure switches: we use the Reflex for this. http://refflex.com/content/en_frame.htm
    We have lengths of 20 m of tube and we crimp on the tube the adapter we need we a crimping tool very similar like those you use for electrical connections.
    In the picture, the small grey ones.
    For the refrigerant connections, we use or Burgaflex or Parker.
    The Burgaflex needs to be coupled with a special big crimping tool. We go to the wholesaler and we say what we need and he makes the hoses for us within 5 minutes.
    But with the Parker system, you buy the hose and the adapters you need and you can screw them on the hose (cut th hose on length on-site) on-site, gas-tight with only 2 spanners. Easy for repairs.
    Here in Belgium, Parker is distributed by ECR. Not all adapters are hold in stock by ECR.
    Jun 2009
    North East England
    41
    712
    Re: Flexible lines
    or you could use off the shelf flexible braided hose available from most refrigeration suppliers they start at 12"up to 60"
    Scotland
    327
    Re: Flexible lines
    Thanks everyone.
    The steel braided is definately an option but it doesn't come cheap, the crimping tool is about the same price, the rubber hose is braided on the inside, I beleive.
    I wondered about coiling the copper itself into a spring before fitting onto the units, is this a viable method?
    Jun 2009
    North East England
    41
    712
    Re: Flexible lines
    you dont need tools for the steel braid they come with female 1/4 flare on either end coiled copper is an option i use it quite a bit to reduce vibration
    Nov 2006
    708
    23
    Re: Flexible lines
    Hose depot direct
    (01302) 746969
    Give these a call , they will make any length ,any fitting , for any thing
    Speak to Paul
    Sep 2010
    7
    Re: Flexible lines
    I wouldn't recommend the Burgaflex bubble crimp style of hose system. The crimp joint is not the best, we had problems over many years with these.
    We now use Aeroquip EZ-Clip hose and fittings and have had no problems (except avoid the -16 size). Hose assemblies can be made on site with no special crimping tools required. Burgaflex have a similar clip system as do Manuli.
    Sorry can't post URL's.
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: Flexible lines
  1. Replies: 2
    Last Post: 16-05-2010, 03:44 PM
  2. Why are discharge lines smaller than suction lines?
    By monkey spanners in forum Technical Discussions
    Last Post: 11-05-2010, 11:28 AM
  3. warped liquid lines
    By kberg in forum Commercial
    Last Post: 13-05-2009, 06:42 AM
  4. LP/HP Connector Lines
    By jwasir in forum Fundamentals
    Last Post: 18-02-2009, 06:06 AM
  5. Rising lines
    By zapoy in forum Fundamentals
    Last Post: 05-05-2008, 07:53 AM
