Thread: Gree KFR-60G/A10
14-06-2005, 09:40 AM #1
Gree KFR-60G/A10
Hello all
Does anybody know why the indoor unit of the above high wall split would be emmiting a constant beeping noise about twice a second.
Unit does not operate at all. As soon as the isolator is turned on the unit starts beeping but does nothing else.
From the limited support I could get on this unit, the seemed to think that it was a problem with the indoor ambient thermistor or indoor coil thermistor.
When I arrived at the job I discovered that my meter was malfunctioning so I couldnt check the thermistors, but I had a new PCB complete with thermistors that they had sent to me. Changing this did nothing for the problem.
Thanks in advance.
14-06-2005, 12:05 PM #2
Re: Gree KFR-60G/A10
Sounds to me like there may be a problem with the interconnects.
Try checking these.
May solve the problem.
haven't had the pleasure of working on a gree as yet.:cool: Do the job once & do it right. :cool:
14-06-2005, 03:12 PM #3
we have installed a few Gree units, but have not suffered this problem.
I could only find this:- www.kievclimate.com/support/files/gree_fy.pdf which may help.
14-06-2005, 08:44 PM #4
Hi Temprite
Try this http://gree-air.ru/support/tech_doc/feng_yun.pdf
page 40IF AT FIRST YOU DON`T SUCCEED.
and go get a cuppa
15-06-2005, 09:59 PM #5
Thanks for the comments all.
Thanks for that chillin.Sounds like that is the same document that the information about the thermistors was sourced from.
I fixed my meter last night,will be heading back there soon.
Strangely enough no one else is climbing over me to do this job.
GREE Suppliers
By gwilliamson in forum DomesticReplies: 15Last Post: 11-06-2009, 06:11 AM -
Gree mobile A/C
By Lucas in forum Air ConditioningReplies: 6Last Post: 31-12-2004, 04:53 PM
