    Apr 2004
    Pakistan
    44
    129
    21
    Absorption chiller cop based on hhv and lhv
    Dear All
    i am so confused with all this HHV and LHV of a chiller. Tell me whether the COP increases with LHV and decreases with HHV?
    Why is it so, when we take LHV(low het value) of gas does the flow rate of natural gas also not increase to give the same heat output?
    As for HHV(high heating value) the flow rate of natural gas will reduce?
    e.g.,
    if LHV of natural gas is 871 Btu/cu ft and that HHV is 970 Btu/cu ft whose COP will be higher.
    Please eleborate......
    Our nose is our personal air-conditioning system: it warms cold air, cools hot air and filters impurities
    Apr 2004
    Pakistan
    44
    129
    21
    Re: Absorption chiller cop based on hhv and lhv
    Apr 2004
    Pakistan
    44
    129
    21
    Any body there to answer?
    Oct 2003
    5,630
    34
    Abbasi, I don't have any experience with absorption machines. I know Frank worked on some.
    Can you speak anyhow of a COP for an absorption machine? I don't know the answer.
    Apr 2004
    Pakistan
    44
    129
    21
    Its a very common query for people working on ABS Machines, how can i contact Frank? should i PM him
    May 2008
    66
    802
    Quote Originally Posted by abbasi View Post
    Dear All
    e.g.,
    i think you need more than low or high heat values to calculate the cop of anything /something.
    what cind of cop are you trying to find?
    the hole plant COP? the cooling or heating COP?
    cop in coöperation whit EER?
    Ice
