Results 1 to 2 of 2
    thermetrics's Avatar
    thermetrics Guest
    Exclamation Help- need to find an obsolete part
    I am new to this website, so please forgive me if this is not the correct place to post.
    I am the office manager for an commerical/industrial HVAC company in Central Florida.
    We have several Carrier 23XL Frame 4 D60 chillers under a maintenance agreement. I just received a call from the tech that we lost a motor, I contacted Carrier RCD-parts dept, the Ingersoll motor is obsolete. I am trying to locate a replacement motor, anywhere possible. The part number is 5T2FGH11 The techs are in the process of removing the motor and checking to see if we can send it to a machine shop to rewind it, but if the stator slots are burnt we will have to replace.
    So, to get to my question--- Does anyone have a Carrier motor available? Or do you have a source I could contact?
    Thanks so much.
    United States
    167
    Re: Help- need to find an obsolete part
    Best info I can pass on goes like this... we use a motor house called Dreisilker Electric Motors. The closest location to you is Marietta, Ga. but they will ship 50 states and repair most everything. Their phone is 770-272-0773. Ask for tech support to get better 1 on 1 help. Next best selection choice for cross-reference is Grainger. I have a listing for Melbourne, Fl. Their number is 321-951-1985. They have GREATLY improved their comm. level of assistance lately and inventory is much better. Well...at least here in Chicago. Hope it helps . Good luck. Just an after thought...Carrier is TEC...Temperature Equipment Corp. and has locations in Florida. I don't know how old the chiller is but parts must be made available , whether OEM or equilavent, for 10 years unless company goes out of business. I might opt to check directly with TEC and their senior duty engineer to help locate their answer to your motor. I've done it before and spent 8 yrs. running a parts house where I found those guys to be invaluable.
    Don't leave it like you found it.....Leave it like it should be !!!
  1. Spare part help, from EUA to México
    By AlexLPD in forum Commercial
    Last Post: 25-06-2010, 04:21 AM
  2. EN 378 revision
    By Argus in forum Legal-Business-Marketing
    Last Post: 19-11-2008, 07:21 PM
  3. part p
    By eggs in forum Electrical
    Last Post: 15-11-2007, 08:55 PM
  4. Filter-drier part number question
    By Larry2 in forum Fundamentals
    Last Post: 24-11-2006, 05:46 PM
  5. Replies: 1
    Last Post: 19-02-2006, 12:08 AM
Tags for this Thread
