    Little Red's Avatar
    Little Red Guest
    Auto AC. R12-R134a conversion... oil?
    Hi everyone,
    Iím not an AC techie, nor a chemist or biologist, so I have become completely lost in the various internet sites and conflicting information. All I am trying to do is convert my auto AC from R12 to R134a and would appreciate some advice.
    Car is a 93 Corvette and was running R12. The compressor (Denso 10PA20C) developed a front shaft seal leak, so in my infinite (or not) wisdom, I decided to totally rebuild the compressor with new bearings/thrust washers/seals etc. No problem so far, the comp is on the bench in a 100 pieces and thankfully no signs of undue wear or any particle contamination and it should go back together ok.
    NowÖ!!!, not knowing anything about AC, my info comes from the net and here is where Iím stuck/confused.
    ......what type of oil do I use for this compressor with a R134a retrofit?
    Iíve read that it should be PAG46 (Densoís recommendation for the comp), Iíve also read that it should be a 100 viscosity Ester oil (so that it doesnít react with any residue oil left in the system), another opinion suggests a PAG Ďd-cappedí, what and why the later is I donít know.
    In a fleeting moment where I thought I understood what was needed, I went and bought a liter of ĎEmkarate RL2000í that the garage salesman waved under my nose. Iím now not sure if this is the correct oil and particularly if it is the right viscosityÖ the product sheet says ISO68 !?
    Another web contradiction Iím coming across is whether itís a good idea to flush the system or not, if so what with and how?
    Any opinions/suggestions please?
    Many thanks.
    PS: I know I need new R134a compatible seals, gauge/charge adaptors and Iím fitting a new accumulator/drier for good measure. Iíll also have the system recharged at 60-70% of R12 recommendations
    Oct 2008
    mallorca, spain,
    69
    771
    13
    Re: Auto AC. R12-R134a conversion... oil?
    hi little red ,
    just to add to your list there is a pressure test , a leak test, the system needs evacuating, then gassing up ? are you registered ?
    you may be better advised to find a repitable garage ? but all the best in your venture.
    Little Red's Avatar
    Little Red Guest
    Quote Originally Posted by sedgy View Post
    hi little red ,
    Hi sedgy,
    I didn't know about a pressure test, what is that one?. It's already evacuated (prior to stripping the compressor). I was planning on getting a good long vacuum applied as a leak test prior to regassing.
    I'm in Spain, like you, but unfortunately in my area there isn't a decent AC shop. When I had the R12 evacuated I noticed that they were purging into the same machine they use for R134a and I didn't think that to be right! (unless it is ok?)... so I'll find another garage for regassing.
    Don't know what you mean by 'registered', I'm not an AC Tech.
    Nov 2009
    Poland
    80
    9
    Replace the filter dryer, pull well and then fill the vacuum system R409A
    This is a replacement for R12 in the same quantity.
    The problem with the remake is that in addition to replacement of all rubber parts will not know how much 134a fill volume falls because less of it
    43
    3,794
    38
    Be better off putting 5gs mineral oil back in and running it on a R12 drop in such as R413A, unless you plan to change all the flexi hoses too.
  1. Freeze Spray -- Venting R134a Illegal?
    By Z2TT in forum Chit Chat & Service Stories
    Last Post: 29-07-2010, 09:29 PM
  2. R507 in an R134a compressor: any danger?
    Last Post: 21-12-2009, 01:44 AM
  3. Clogged condenser leading to no gas on R134a systems?
    By runningonavac in forum Refrigerants
    Last Post: 01-09-2009, 10:52 PM
  4. R12 to R134A conversion
    By northern-tech in forum Commercial
    Last Post: 26-06-2006, 06:24 PM
  5. Replies: 5
    Last Post: 01-03-2004, 10:59 PM
