Hi there,
I recently brought a this fridge second hand, when I went to pick it up the guy showed me it working.
We switched it off at the mains, then I took it home.
I let it stand for 24 hours before plugging it in.
When I plug it in the temps flash and I set the fridge to 2 and freezer to -18.
The freezer has got to temp but the fridge is still at 21 degrees?
I have tried doing a reset (turning off and back on after 1 min) and all that happens is that the temp lights flash, then a number 3 appears on the right hand (fridge) temp, before the temps show up again.
It sounds like the fridge is running.
I have the ice maker switched off as it is not connected to the water supply, and also the filter needs changing (red light on front).
Can anyone help or advise where I can get the service manual for this ?
I live in Southampton and my email is stuart.oconnor@ymail.com
