Thread: Acoustic Insulation for Ductwork
17-08-2010, 08:27 AM #1
I am installing a throttle for a series of duct work for a fan test rig.
This throttle will be used to control the air flow into the ductwork . However, since this is a fan test rig, thus noise will be generated.
I am planning to install a acoustic insulation to the throttle and into the entrance duct to minimize the noise. So, the insulation would not be fixed for the entire duct work.
But I am not sure what type of acoustic insulation should be installed to it. And should the acoustic insulation be able to withstand the fan noise level as mentioned in the fan specification ?
17-08-2010, 09:09 AM #2
Re: Acoustic Insulation for Ductwork
17-08-2010, 09:25 AM #3
Further to my last post to you, also Google "Woods Practical Guide to Fan Engineering" section 18 covers all aspects of Noise in Fan Systems and deals with accustic properties of materials.
There is an on line version of this which you can download and print.
Have plenty of paper and ink, it runs to 300 pages.
Best of luck
17-08-2010, 11:09 PM #4
Why not just fit a sound attenuator to the inlet prior to your damper.
http://www.kineticsnoise.com/industr.../circular.htmlBrian - Newton Abbot, Devon, UK
Insulation for Cold Room
By tjk2007 in forum FundamentalsReplies: 25Last Post: 19-03-2010, 03:54 AM -
Help needed sourcing insulation for a Display Case
By jimbo22 in forum Technical SpeculationsReplies: 2Last Post: 03-11-2008, 10:30 AM -
Emmisivity as insulation thickness determinant ?
By sharshal in forum Technical SpeculationsReplies: 4Last Post: 23-10-2006, 02:26 AM -
thermo acoustic refrigerator: problem with stack heating
By jackal in forum Technical DiscussionsReplies: 6Last Post: 04-09-2006, 05:03 PM -
Suspended Floor Insulation
By Colin Kaminski in forum CommercialReplies: 2Last Post: 08-02-2006, 07:10 PM
