    Aug 2010
    Australia
    12
    Acoustic Insulation for Ductwork
    I am installing a throttle for a series of duct work for a fan test rig.
    This throttle will be used to control the air flow into the ductwork . However, since this is a fan test rig, thus noise will be generated.
    I am planning to install a acoustic insulation to the throttle and into the entrance duct to minimize the noise. So, the insulation would not be fixed for the entire duct work.
    But I am not sure what type of acoustic insulation should be installed to it. And should the acoustic insulation be able to withstand the fan noise level as mentioned in the fan specification ?
    Mar 2008
    232
    Re: Acoustic Insulation for Ductwork
    Quote Originally Posted by titanum456 View Post
    All the information you need can be found in "Wood Practical Guide to Noise Control"
    Google to above all the information you need is in there.
    I don't know if there is on line version but it will lead you to a source of a hard paper copy.
    Mar 2008
    232
    Further to my last post to you, also Google "Woods Practical Guide to Fan Engineering" section 18 covers all aspects of Noise in Fan Systems and deals with accustic properties of materials.
    There is an on line version of this which you can download and print.
    Have plenty of paper and ink, it runs to 300 pages.
    Best of luck
    11,025
    Why not just fit a sound attenuator to the inlet prior to your damper.
    http://www.kineticsnoise.com/industr.../circular.html
  1. Insulation for Cold Room
    By tjk2007 in forum Fundamentals
    Last Post: 19-03-2010, 02:54 AM
  2. Help needed sourcing insulation for a Display Case
    By jimbo22 in forum Technical Speculations
    Last Post: 03-11-2008, 09:30 AM
  3. Emmisivity as insulation thickness determinant ?
    By sharshal in forum Technical Speculations
    Last Post: 23-10-2006, 02:26 AM
  4. thermo acoustic refrigerator: problem with stack heating
    By jackal in forum Technical Discussions
    Last Post: 04-09-2006, 05:03 PM
  5. Suspended Floor Insulation
    By Colin Kaminski in forum Commercial
    Last Post: 08-02-2006, 06:10 PM
