Results 1 to 2 of 2
    Waynexb's Avatar
    Waynexb Guest
    majonnia carbo cooler not at temp
    hi everybody hoping for some help. my majonner is not achieving product tempreture of or below 2 degrees c . the product temp in is 10 degrees c and the back pressure valve is set at -2.we have always had a product temp of 4 degrees before . could there be a blockage in the carbo coolers liquid inlet. its a flooded type with a mycom 8cyl behind it.
    Thanks Wayne
    3,357
    Re: majonnia carbo cooler not at temp
    Try draining oil from all low points on surge drum & carbo plates ..
    In some cases empty all ammonia out , then drain .
    Hopefully there is drain valve on lowest points & pipework slopes towards drain valves .
  1. mojonnier carbo cooler common system
    By guapo in forum Industrial
    Last Post: 16-06-2011, 05:20 PM
  2. Cannot get the cooler to temp
    By coolrunnings1 in forum Fundamentals
    Last Post: 27-06-2009, 07:51 PM
  3. low temp txv in cooler
    By jcool808 in forum Trouble Shooting
    Last Post: 11-03-2009, 06:57 AM
  4. Compressor loading, cooling, and range of operation.
  5. Carbo Cooler relief valve
    By flasah in forum NH3
    Last Post: 24-06-2006, 09:31 AM
