Results 1 to 2 of 2
14-08-2010, 03:29 AM #1
Designing Systems for Beverage Coolers
Is there a way to rate Systems for Beverage Coolers similar to how Room AC systems are sized to be standard dimensions and ratings?
15-08-2010, 02:38 AM #2
Re: Designing Systems for Beverage Coolers
hi mmaragh,
some designer use the A/C computation for beverage cooler. But my advice, you compute it base on ref system heat load. you will notice the difference
thank you
lynark
Vrv
By tgoonter in forum Air ConditioningReplies: 4Last Post: 11-01-2011, 07:25 AM -
Sensible Heat Factor / capacity of Inverter split Systems at part load?
By Greengrocer in forum Technical SpeculationsReplies: 31Last Post: 09-02-2009, 05:57 PM -
Co2 Systems in Supermarkets
By 750 Valve in forum Supermarket RefrigerationReplies: 22Last Post: 19-10-2007, 08:51 AM -
Suction line designing for ref. systems
By Maxim in forum FundamentalsReplies: 19Last Post: 16-12-2006, 06:43 PM
