12-08-2010, 08:13 PM #1
How would you design an ammonia system.... in space
Looks like another requirement to be an astronaut is to be an ammonia tech.
http://www.npr.org/templates/story/s...ryId=128932238
After reading this article I was wondering how one would build an ammonia refrigeration system in space.
How would you deal with the fact of no gravity, all the liquid would not sit at the bottom of the High pressure receiver, and the pumps would not have sufficient NPSH.
Or how would you condense without wet bulb or even an atmosphere to reject heat to.
12-08-2010, 08:58 PM #2
Re: How would you design an ammonia system.... in space
WHY WOULD YOU WANT TO?
Surely in a negative atmosphere the problem would Lack of heat?
13-08-2010, 07:54 AM #3
Grizzly, the station is surrounded by almost a vacuum, with 'nothing'
So all the heat generated inside the station remains in the station. If you install a heat exchanger outside the station, there's even no air to change your heat with. Seems not that easy.
Even a 'simple' airliner uses its 'expensive compressed energy' of the turbines to generate cold they need inside the cabin and it's mostly -50°C outside.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
13-08-2010, 02:58 PM #4
The heat from all the electronics is rejected out as infrared radiation by large radiators.
http://science.nasa.gov/science-news...01/ast21mar_1/
I'm assuming the "cooling pump" they've been having trouble with is actually a compressor of some kind because 700# is a HELL OF A PUMP.
21-10-2010, 08:24 AM #5
I am no scientist, with that said I believe that you can overcome the gravity issue by using centrifugal force. It would be like taking a balloon that is half filled with air and half filled with water and swinging it around by the knot! The water would hug the outer extremes. as an added bonus if you spin the vessel fast enough you may not even need a pump.
And the condensation problem is easy
we can replicate that kind of atmosphere easily i would think!
problem in ammonia thermosyphon system
By ghanghas85 in forum NH3Replies: 22Last Post: 29-05-2010, 01:38 AM -
System Burn Out Troubleshooting
By altaf22m in forum Technical DiscussionsReplies: 13Last Post: 07-05-2010, 09:24 AM -
High Liquid Line Temperature
By airefresco in forum CommercialReplies: 37Last Post: 11-02-2009, 04:36 PM -
Ammonia system design
By ingherrera in forum NH3Replies: 16Last Post: 08-03-2007, 02:58 PM -
Ammonia Transfer System
By gwapa in forum FundamentalsReplies: 7Last Post: 12-09-2006, 01:12 PM
