Thread: Matching compresser duty
11-08-2010, 10:42 PM #1
I am needing help match up compresser duty. The old compresser is a semi hermetic 1/3 hp running at 1750 rpm giving 2.37 m3ph. I want to fit a hermetic compresser but they are sized up in cm3 displacement but do not say what their rpm is. Do all hermetics run at the same speed or are there different speeds?
12-08-2010, 03:54 AM #2
12-08-2010, 04:36 AM #3
Re: Matching compresser duty
As you long as the displacements the same, the refrigeration duty etc are the same, you should be fine irrelevant of what type of compressor you use.
12-08-2010, 05:07 AM #4
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
matching & Balancing between Evaporator and Compressor ??
By M.Saleh in forum Trouble ShootingReplies: 1Last Post: 24-01-2010, 09:44 AM -
Matching & Balancing between Evaporator and Compressor
By M.Saleh in forum Air ConditioningReplies: 3Last Post: 22-01-2010, 01:48 PM -
Ice forming on compresser?
By jbomba in forum Trouble ShootingReplies: 12Last Post: 27-04-2009, 01:25 AM -
Compresser electricals - HELP me please!!!
By pjalchemist in forum ElectricalReplies: 38Last Post: 28-11-2008, 12:09 PM -
sensible cooling duty of a cooler
By samiam in forum FundamentalsReplies: 8Last Post: 16-02-2008, 05:49 PM
