Results 1 to 12 of 12
    Nov 2006
    Poland
    91
    NH3 pipe diameter selection diagram.
    Hello Guys,
    I'm looking for diagrams to select pipe diameter for ammonia refrigeration installations. It would be great, if you had the diagrams with SI units.
    Many, many thanks in advance for your assistance.
    Regards,
    Jacek
    Jul 2005
    61
    68
    Re: NH3 pipe diameter selection diagram.
    Danfoss has a selection program you might be able to get from your local dealer. I have looked at it and it does SI units.
    Aug 2010
    110
    14
    You dont have the name of the program do you? I have tried to get the valve selction program from Danfoss UK many times but Danfoss UK are a really unfriendly lot here and the Danfoss agents won't part with what they see as their stuff in case you try and do them out of a job.
    Nov 2006
    Poland
    91
    Quote Originally Posted by McFranklin View Post
    Thanks.
    I forgot about Danfoss.
    Regards.
    Jul 2005
    61
    68
    It is DIRcalc. I haven't tried to download it here at home, but it was free the last time.
    http://www.danfoss.com/North_America...ls/DIRcalc.htm
    I pasted the url above.
    Aug 2010
    110
    14
    I had a quick look at the dircalc program and was not that impressed I'm sure that with a bit of work you would be able to get it to work for you but manual calculation is still the best way.
    Jul 2005
    61
    68
    It's free. And really, since ammonia refrigeration is a specialized niche field you are not going to find much. The companies I have worked for used charts. This line size for a dry suction at this temperature, if it's liquid recirc. use the next size larger.
    May 2006
    India
    74
    399
    You will find it in the r.j.dossat`s book page 494 . It gives you fairly close selection of piping sizes . Besides, oil return in nh3 is not a issue with ammonia , you can size the pipes . Oil separator , knock out vessel , receiver ,oil return to crank case issues are easier to address in nh3 v/s r-22 , r-404a ...... Etc. Even piping layout does not pose problems as would in cfc, hcfc refrigerant groups .
    Dec 2008
    Portugal
    48
    1,020
    Quote Originally Posted by piewie View Post
    Don't total agree.
    The dircalc have in count many parameters that influence the pipe selection because it counts with the correct mass flow rather than the refrigerant capacity.
    Many people think that it is enough to know the refrigerant capacity and the evaporation temperature and all parameters are given to the design of the pipeline.
    Mar 2009
    U.S.A.
    320
    Suggest you use the IIAR piping handbook...Its in both sets of "used" units (not true SI; rather Metric traditional?) and gives you a whole lot better picture of what specific pipe segment is encountering in terms of fluid flow than does dircalc.
    Dec 2008
    Portugal
    48
    1,020
    The dircalc calculates automatically the fluid flow and with inlet section area it calculates the velocity and with the internal D it calculates the pressure drop based on the Reynolds.
    3,853
    Re: were followed
    Quote Originally Posted by efgh516 View Post
    were followed up, low against any winds, praise mid Bangladesh camel smiled, and then repeatedly said: "We are already confident of Mr. Xie, the psyche is willing to submit to the .
    This has oft been a problem with the Bangladeshi camel if proper care and attention have not been paid when living away from its sandy homeland. No one wants a sore camel toe
  1. Wrong pipes diameter - what now?
    By igi in forum Air Conditioning
    Last Post: 06-08-2010, 12:15 AM
  2. pipe and duct selection (needed)
    By solo io in forum Air Conditioning
    Last Post: 26-02-2010, 09:39 PM
  3. Alternative Pipe Diameter Calculation (?)
    By ice_cold in forum Fundamentals
    Last Post: 03-01-2010, 10:33 AM
  4. Pipe diameter, real life and theory
    By gwm121 in forum Fundamentals
    Last Post: 24-10-2009, 04:53 PM
