    Jan 2005
    saudi arabia
    44
    Glycol water valves
    Hi guys;
    I need this information urgently. Can you please tell me what type of valves are used for glycol water systems. Is there a flange type solenoid valve for water glycol ? If not what valve are we suppose to use with glycol water that has a same function as solenoid valve. I really would appreciate if you mention some good manufacturers of glycol water valves with high quality. Please Guys I need Your Help On This One.
    Best Regards;
    Eng AB
    11,192
    Re: Glycol water valves
    You should be able to use most valves with glycol, what do you have available?
    Oct 2003
    5,645
    34
    Don't use valves wich goes open/closes with very fast like a refrigerant SV. This can cause serious liquid hammers in the lines due to the sudden stopped water velocity in the tubes.
    It's better to use slow opening valves (butterfly opened with a slow running servo motor, a heated motor which pushes against a piston,...)
    We use those of Nibco. www.nibco.com and press fittings. Installing goes very fast with these fittings.
    We mainly use them because they're good and very nearby us is a supplier which hold many of these valves in stock.
    For defrosting, we install a bypass over the coil with a small inline electrical heater and a small auxillary pump. As far as I know, an own 'invention'
  1. Hoshizaki Ice Maker
    By Abe in forum Legal-Business-Marketing
    Last Post: 01-05-2010, 03:27 AM
  2. Fact or Fiction
    By david.findlay in forum Fundamentals
    Last Post: 09-03-2009, 07:19 PM
  3. cold river water
    By eftimios in forum Fundamentals
    Last Post: 09-11-2008, 07:37 PM
  4. open cycle R718 A/C that also provides high purity water?
    By star882 in forum Technical Speculations
    Last Post: 27-07-2006, 04:18 AM
  5. Building a wine cabinet
