    sheers's Avatar
    sheers Guest
    l,unite hermetique compressor
    hiya all
    just wondering if any one has some good advice on obtaining a compressor(l,unite hermetique TAJ4511Y) compressor . this unit is 3 phase on R134a non rotar lock(braze stub) on speaking to the larger suppliers there is currently a 7/10 week wait on this,and typically the customer doesnt want to wait this long as its stopping production.im new to the side of ordering equipment and i have fell at the first hurdle.any advice would be appriciated thnx guys
    3,856
    Re: l,unite hermetique compressor
    I'd try Climate centre, RPW/FSW, HRP, United Refrigeration, SRW, Hawco, Thermofrost Cryo, failing that, the equipment manufacturers or whole saler.
    I'd also look at getting a rotalock one instead if one was in stock, or if needs be a whole condensing unit (which i have done in the past when the condenser fan was duff too.
    Then i'd get onto your wholesalers technical dept and ask them to size an equvalent duty replacement.
    At the end of the day its your customers problem that they have equipment that the parts are out of stock for, and your challenge as to how you overcome the problem.
    Sep 2003
    ISRAEL
    72
    4,248
    its a small 1HP compressor.
    Search the web other makes such as Embraco or Danfoss.
    In emergency, you can use CAJ2464Z, it is for 404 but the displacement is almost the same.
    It will do the job.
    Split Croatia
    57
    6,151
    36
    Any compressor with 32,4 cm^3 or simmilar displacement, high back pressure and with POE oil will do the job.
    Maneurop MTZ018-4 or MTZ022-4 will be close (30 or 38 cm^3)
    Embraco (Aspera) NJ6226ZX (34,4 cm^3) also.
    Apr 2008
    Southampton, England
    49
    1,023
    36
    Is it also possible for you to fit a single phase compressor instead?
    Wholesaler should be able to size up the correct one but you'll need a neutral and may need to uprate one of the original 3 phase fuses (yeah, I found that out the hard way...)
    Cheers,
    Andy.
  1. Suction gas <-> liquid line heat exchange and performance gains
    Last Post: 18-05-2010, 01:52 PM
  2. Catastrophic compressor failure...need info
    By bsh3239 in forum Industrial Compressors
    Last Post: 28-11-2009, 04:30 PM
  3. Replies: 3
    Last Post: 29-10-2009, 09:41 PM
  4. seized inv compressor
    By flash in forum Air Conditioning
    Last Post: 09-04-2008, 06:56 PM
  5. SL/SB-400 Pump Down Procedures
    By absolute-zero in forum Transport
    Last Post: 29-01-2008, 09:27 PM
