Results 1 to 12 of 12
    Feb 2009
    new zealand
    5
    hot liquid and suction lines
    probably an easy answer but i cant see why both the liquid and suction lines are hot.
    this is on a 9kw highwall split unit, air off 47 air on 20
    500psi on heat
    but not really performing well ,as in it doest kick up to high fan, and no its not oversized.
    any ideas
    Feb 2010
    Ireland
    38
    82
    15
    Re: hot liquid and suction lines
    U sure your compressor is pumping?
    Feb 2009
    new zealand
    5
    yes hence 500psi
    Feb 2009
    new zealand
    5
    also sounds like is boiling in the indoor unit
    3,856
    Filters and coil clean? Fan blade/blower wheel clean?
    Where are you taking your temperature measurements? Just wondering as the interconecting pipe work will be hot during heating mode. I expect the liquid line is in fact an expansion line.
    Sep 2003
    ISRAEL
    72
    4,248
    500 psi sounds like you use air as refrigerant.
    Evacuate and recharge.
    Check that 4 way valve performs OK.
    3,856
    Like Chemi says thats a high pressure, what refrigerant is it using? I hope the system is on R410A with pressures like that!
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by djs View Post
    500psi on heat
    any ideas
    What is unit make and model? What is outdoor temperature?
    On high wall split system in heating mode both lines are part of condenser and therefore both should be hot.
    One hotter than another (one little below of compressor discharge temperature and other little below condenser saturation temperature).
    Recover and weigh charge. It is best to evaluate performance by observing temperature difference and air flow before recovery and evacuation.
    Δt of 27°C at indoor heat exchanger is sligtly high and could point to problem with insufficient air flow. Maybe fan speed is not on high, or filter and heat exchanger is dirty, or fan condenser is faulty, etc...
    If you have lines longer than unit is charged for, you need to calculate additional amount of refrigerant and see if it is added or not.
    Than charge correct amount and see if unit is performing OK by measuring air flow and air in and out temperature difference.
    Split Croatia
    57
    6,151
    36
    Chemi, it could be R410a.
    500 PSI is 34.5 Bar which is 57°C CST which looks to me perfectly OK.
    Sep 2003
    ISRAEL
    72
    4,248
    You can be on the right side, lets wait and see.
    Meanwhile you can enjoy the Chinese drivers....
    http://www.youtube.com/watch_popup?v=QESfEd180rQ
    Split Croatia
    57
    6,151
    36
    At least they are driving pretty slow.
    Feb 2009
    new zealand
    5
    thanks for all replys ,it is on 410A so i expect around 500psi, the pipe is only 3mtrs so the supplied charge should be ok.
    imthinking i might move the themostat from the unit to the opposite wall.
    the unit is a mitsubishi ge80
  1. Superheat and Subcooling
    By Chunk in forum Fundamentals
    Last Post: 15-01-2011, 01:24 AM
  2. Liquid charging through the suction side
    By deu58 in forum Fundamentals
    Last Post: 02-07-2010, 05:23 AM
  3. Suction gas <-> liquid line heat exchange and performance gains
    Last Post: 18-05-2010, 01:52 PM
  4. Parker levels in ammonia systems
    By Friobernal in forum Industrial
    Last Post: 04-08-2005, 03:46 PM
