Results 1 to 10 of 10
Thread: vilter compressor
09-08-2010, 09:24 PM #1
vilter compressor
hi guys,
i have a vilter compressor running on R22 for ice builder with 4 F suction temp and 112 F condensing temp. now the problem is worn out on the outer seat of the discharge valve. What do you think made this? any one can help?
thank you
09-08-2010, 09:28 PM #2
Re: vilter compressor
Is it a new system with a lot of steel pipe ?
What model of Vilter & type of discharge valve ie ring type valve plate ?
09-08-2010, 10:02 PM #3
vilter 450. the high suction safety head was already replace for R22 application. but still there's a problem on the worn out discharge valve
09-08-2010, 10:04 PM #4
15-08-2010, 06:41 AM #5
we have had it where the discharge saftey spring had lost their tension alowing the discharge plate to bounce.is it an old machine
15-08-2010, 10:09 AM #6
I have seen a case of the discharge valve rings actually wearing right through the valve plates .
This was a R22 plant with Sabroe compressors .
The plant was new & put it down to steel pipe dust,scale etc .
Replaced once & all OK .
Didn't seem to wear anything else but discharge valves .
Maybe this happened to you .
15-08-2010, 04:33 PM #7
hi ranger1,
the worn out safety was already replace we are monitoring now the operating temperature/pressure hopefully we can find the root cause of the problem. because there are two ice builder. the ice builder 1 is running without problem for so many years on the ice builder 2 ( new one but total replica of the ice builder 1 ). that is why can't seem to understand what went wrong
thank you
lynark
20-08-2010, 02:05 PM #8
hi Ranger1,
forgot to mention there are 3 compressor with 1 common suction header and liquid header.
also got the running details.
suction pressure: 21 psi
discharge pressure: 255 psi
ampere: 101
suction pressure: 19 psi
discharge pressure: 215 psi
ampere: 96
the design specs of ice builder are 4 F (27 psi ) suction and 112 F condensing temp.
thank you
lynark
20-08-2010, 10:08 PM #9
Can you post picture of worn out discharge valve and/or a vilter part number .
You also have 255 psi discharge on one compressor , is the an error .
22-08-2010, 02:11 AM #10
hi ranger1,
ok i'll try to pose some pictures. The outer ring of the safety head is the one being worn out. part number 517 of vilter parts
But now the problem is got broken piston with lots of metal debris just open up the compressor yesterday to check the odd sounds its making. oil filter are full of black sludge so maybe the broken piston is due to lubrication failure but still checking the system.
about the discharge pressure, 255 psi is correct that the highest recorded pressure the lowest is 215 psi they give me.
thanks for the help
lynark
MP66 & Compressor Overheating
By Intermez in forum Technical DiscussionsReplies: 111Last Post: 13-04-2010, 08:58 PM -
copeland scroll durability
By Third_techtrio in forum Technical DiscussionsReplies: 16Last Post: 23-01-2010, 04:47 AM -
Catastrophic compressor failure...need info
By bsh3239 in forum Industrial CompressorsReplies: 40Last Post: 28-11-2009, 04:30 PM -
Thumping noise in the compressor
By Husky250 in forum Air ConditioningReplies: 6Last Post: 16-05-2008, 10:48 PM -
Compressor Capacity
By engrkate in forum FundamentalsReplies: 15Last Post: 13-10-2006, 12:11 AM
