Results 1 to 2 of 2
09-08-2010, 01:15 AM #1
Amcoraire split air 1200 BTU AOS121HX
Hi all,
I'm a new member and hope you guys could help me out of this problem.
Last year in May I purchased 6 units of Amcoraire with 4 of 9000 BTU are still running perfectly but 2 of 12000 BTU AWS121HX are having 2 differences.
Last week, one of them has the F1 code flashing on the oinside unit and anytime I started the fan of the inside unit running for about 30 seconds and the code F1 shows up.
The other one's problem just started today. last night i still used it and was good. This morning, when I started it up and the fan of the inside unit was running and after awhile I realized that what I got was only heat and heat.
It is still in the middle of summer. Amcoraire company is out of business. I don't where else asking for help. I searched on Google and I found you guys want to help people who are in problems.
I'm waiting for good news.
Thanks for your time.
11-09-2010, 04:08 AM #2
Re: Amcoraire split air 1200 BTU AOS121HX
I'm surprised no one answered you yet...
Pridiom.com now carries the Amcor line. They won't warranty one that wasn't bought through them (how convenient) but they'll be happy to charge you for whatever spare parts you need.
Can't help with the one problem but the F1 means your the indoor/outdoor units arent talking. A VERY common problem with them, and usually means the outdoor pcb is fried.
Fujitsu Split System Outdoor Fan Wiring Issue
By damo_666 in forum Air ConditioningReplies: 3Last Post: 29-03-2010, 03:04 AM -
How good is your split system running?
By acnerd in forum Air ConditioningReplies: 18Last Post: 05-08-2009, 07:35 PM -
3 single split units or one multi split - consumer advice needed
By kok in forum Air ConditioningReplies: 18Last Post: 15-04-2009, 08:42 PM -
Sensible Heat Factor / capacity of Inverter split Systems at part load?
By Greengrocer in forum Technical SpeculationsReplies: 31Last Post: 09-02-2009, 04:57 PM -
Australian split installers, some info needed
By paul_h in forum Air ConditioningReplies: 10Last Post: 20-05-2008, 03:40 PM
