07-08-2010, 03:17 PM #1
sizing phisical dimensions of a freezer room
I am busy with freezer room for fish
It should hold 15 ton in approximate 30 kg boxes
what guides should I follow to determine the proper phisical dimensions?
thks
07-08-2010, 09:18 PM #2
Re: sizing phisical dimensions of a freezer room
15000/30 = 500 boxes
500 to be stored in racks, pallets + free space above and around the pallets/racks for proper air circulation.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
08-08-2010, 01:29 AM #3
5 m x 5 m x 4 (height) m it will be enough.
08-08-2010, 10:30 AM #4
most important you forgot to tell us: are the goods already frozen when entering the freezer room?
08-08-2010, 10:52 AM #5
Peter
Yes the fish are frozen when entering
Where can I find guides on the shelving arrangement etc.?
09-08-2010, 01:49 AM #6
Use the good sense.
1) Don't block the air circulation between the stacks of fish boxes;
2) Load only until underneath the aircooler so no air will be blocked
3) Let a space between the walls and the shelves so the cold air can pass through.To make progress is never good enough, I want to do better and better and better
Freezer Room Design
By MazlanZ in forum Technical SpeculationsReplies: 9Last Post: 18-08-2010, 12:23 PM -
Maneurop MT51HK4A - Freezer Room
By Hatchy in forum Trouble ShootingReplies: 35Last Post: 09-08-2010, 12:10 PM -
freezer room equipment
By jack smith in forum Tools and CalculatorsReplies: 4Last Post: 12-06-2010, 05:27 AM -
Cold room/ Freezer combo.
By dogma in forum CommercialReplies: 14Last Post: 09-11-2008, 02:25 PM -
Freezer Room Panels
By Feeze in forum Technical DiscussionsReplies: 10Last Post: 22-04-2005, 05:58 AM
