Results 1 to 8 of 8
    Dec 2004
    Weihai,China
    800
    electric cabinet cooling
    Hi sirs
    How about the application of thermoelectric air conditioner to the cabinet cooling? Is it more reliable than compressor refrigeration system ?
    anybody can share me some information here? thanks in advnce
    regards
    LC
    Aug 2007
    Sydney
    52
    1,083
    23
    Re: electric cabinet cooling
    Hi Lc shi
    It really depends on the application and load size. Thermoelectric is drastically less efficient than vapour compression. If it is for something like a humidor (small to medium) then it's OK. It is reliable and simple to control with electronics, hence reliable. So for small loads it's cool - but not for bigger loads.
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    Hi LC SHI ,as tesla says thermoelectric is far less efficient. a good example are the small plug in car fridges, runs 4 amps on 12 volts all day to cool about 10c below ambient where a compressor driven car fridge running 4 amps can cool around four times the space and cycle at 30c below ambient.
    Dec 2004
    Weihai,China
    800
    thanks for your information. I'll look for the compressor system.
    regards
    LC
    Nov 2007
    London
    461
    I have worked on plenty of the Rittal units and they are pretty good.
    http://www.rittal.co.uk/products/sys...rol/index.html
    Sep 2003
    ISRAEL
    72
    4,248
    Quote Originally Posted by brunstar View Post
    they are very good and so are these http://polak.co.il/_Uploads/269AirAir.pdf
    Aug 2010
    US
    54
    8
    Cabinet coolers use a vortex tube that converts compressed air into cold air to cool.So cooling can be done easily.
    Sep 2003
    ISRAEL
    72
    4,248
    A waste of energy.
    To receive 1 KW of work from compressed air, you will need 8 KW electricity!!!!
    Most electric boards use refrigerants as cooling substance. Mainly R-134a.
  1. Cooling problem with VRV REYQ24M7.
    By cool#9 in forum Air Conditioning
    Last Post: 07-02-2010, 12:20 PM
  2. Compressor loading, cooling, and range of operation.
  3. SR2 50 models electric SBY diagonostics made simple
    By absolute-zero in forum Transport
    Last Post: 04-01-2008, 05:11 PM
  4. Cooling tower evaporation, blowdown, makeup and cycles
    By miltbeychok in forum Industrial
    Last Post: 14-10-2005, 06:34 PM
  5. Cooling tower evaporation, blowdown, makeup and cycles
    By miltbeychok in forum Fundamentals
    Last Post: 13-10-2005, 05:14 AM
