Thread: Phase Change Material
04-08-2010, 07:41 AM #1
Hi..
I want to know more about this technology. Can we use this technology supermarket (open refrigerator) to reduce the power consumption or it's simply storage of energy and overall power consumption remains same...
Regards,
Keyur
04-08-2010, 10:07 PM #2
Re: Phase Change Material
I think that you need to do some reading on this subject.
http://en.wikipedia.org/wiki/Phase_Change_MaterialBrian - Newton Abbot, Devon, UK
05-08-2010, 11:35 AM #3
I Was busy for some time with PCM's but I don't see an application in supermarkets. It's more for energy storage
15-08-2010, 05:36 PM #4
Hi peter...
thanks for the help. Can we use this inplace of heat pipe?
Regards,
keyur
15-08-2010, 05:50 PM #5
I don't see the similarity between the 2 products: a heat pipe transfers the heat from one place or material tot another place/material while PCM stores energy using the latent heat of the PCM.
20-03-2011, 06:14 PM #6
Hi Keyur,
I'm pretty sure that PCM can be effectively used in an open supermarket refrigerators. This way you'll be able save energy, shift the peak load and probably reduce the size of refrigerating equipment.
Flat panels can be layered on the bottom of the refrigerator, some cover on top and then meat or seafood.
What is the temperature in the refrigerator?
Inorganic non-toxic PCM00P or PCM07N (free advert removed)
PCM00P - phase change at 0C,
PCM07N - phase change at -7C.Last edited by Brian_UK; 20-03-2011 at 10:59 PM. Reason: Read forum rules.
Phase change project - need advice.
By moswald in forum CPU OverclockersReplies: 6Last Post: 21-08-2010, 06:03 AM -
Capillary Tube Characteristics
By Chef in forum FundamentalsReplies: 9Last Post: 10-03-2009, 01:03 PM -
CO2 phase change video
By US Iceman in forum CO2Replies: 29Last Post: 12-04-2008, 12:52 PM -
SR2 50 models electric SBY diagonostics made simple
By absolute-zero in forum TransportReplies: 5Last Post: 04-01-2008, 05:11 PM
