Thread: Annie Hermetic Tester
02-08-2010, 12:01 AM #1
I see the Annie Hermetic tester is for a 60 Hz supply.
Do any of you British folk (or anyone else for that matter!) know if using it on a 50Hz supply causes problems or doesn't it make a difference?
Cheers,
02-08-2010, 11:28 PM #2
Re: Annie Hermetic Tester
It won't make any difference to the starting side of things, not sure about the accuracy of the ammeter side of things though.
Never had trouble with mine.
Andy
04-08-2010, 07:55 PM #3
Thanks for the reply. There was one on ebay but went for over £100 in the end.
I carry out normal compressor checks, test capacitors on my meter for value, measure the relay coil for resistance, take the relay apart to check inside. So really I'm not sure if the Annie would tell me anything I wouldn't have found out anyway. If one came along cheap enough then I'd sure like a fiddle though.
Do you find it comes in useful?
Cheers,
08-08-2010, 05:41 PM #4
i have one when i did domestic good bit of kit
cheers
Annie A-12 hermetic compr tester
By Peter_1 in forum ElectricalReplies: 27Last Post: 30-04-2010, 02:50 PM -
oil level indication / sample port in hermetic compressor
By friocold2008 in forum Supermarket RefrigerationReplies: 8Last Post: 17-11-2009, 10:30 PM -
do we need a hermetic or semi hermetic comp.?
By duraid in forum FundamentalsReplies: 14Last Post: 17-04-2007, 05:52 PM -
Good old annie
By Cary in forum Tools and CalculatorsReplies: 7Last Post: 27-03-2005, 10:25 PM
