    Music City Ref's Avatar
    Music City Ref Guest
    Question Thermo King CB C1-10 C
    Gentlemen and Ladies,
    Greeting to all fellow Reefer Men from here in Music City USA. I am in need for a schematic on an older Thermo King Unit.
    The details:
    M/N: CB C1-10
    S/N: C423874592
    B/M: 712978
    R12 8.5 lbs
    I replaced the Low-Pressure cut-out as it had a hole rubbed in the capillary line. I thought that was the only issue, but was incorrect in this assumption. I've checked the control board, diode, fuses, and all associated controls in the control panel and box. I can get the compressor to energize by applying 12V directly to the clutch assembly, but not automatically. The problem that I'm encountering is that all of the identifying nomenclature on the wires have been bleached out by the Sun... So, the dilemma that I face is akin to finding a needle in a needle stack...
    I am an independent contractor and would greatly appreciate any help in this vexing matter.
    Thank You,
    Music City Ref
    Dec 2004
    U.K
    49
    517
    15
    Re: Thermo King CB C1-10 C
    Quote Originally Posted by Music City Ref View Post
    The details:
    M/N: CB C1-10
    S/N: C423874592
    B/M: 712978
    R12 8.5 lbs
    Thank You,
    Music City Ref
    I think I may have the schematic you need, can you PM me with your email address?
    Cheers,
    djbe.
    Quote Originally Posted by djbe View Post
    Cheers,
    djbe.
    Hello djbe,
    Thank you for the quick response
    My email is:
    sarnia_rocks@yahoo.com
    Thank YOu in Advance for helping me get this unit back ion tip top shape!
    Best Regards,
    Music City Ref
    Nov 2009
    Poland
    82
    9
    Enter your email to send you a pdf file
  1. Replies: 12
    Last Post: 27-03-2011, 04:12 AM
  2. Thermo King
    By pkfo in forum Technical Speculations
    Last Post: 19-05-2010, 01:17 PM
  3. Thermo King SB 310 Manual
    By Reefer tech in forum Fundamentals
    Last Post: 15-04-2010, 07:11 PM
  4. Thermo King Refrigerant Help!
    By jingua_ph in forum Transport
    Last Post: 12-04-2008, 01:19 PM
  5. Thermo King v? 00 MAX Tc Wiring Diagram
    By Chris2005 in forum Transport
    Last Post: 01-02-2006, 08:01 AM
Tags for this Thread
