Results 1 to 2 of 2
    RobTi's Avatar
    RobTi Guest
    Hotpoint Mistral replaced both thermistors now what
    Hi all
    I had the high tempreture problem with my fridge freezer (high temps on both), so got the 2 sensors yellow & green and fitted them, also cleaned out the bottom grills and left for 24 hrs to defrost.
    All worked fine for the last few weeks now i have the same problem back again, is there asnything else i could try ?
    Robert
    RobTi's Avatar
    RobTi Guest
    Re: Hotpoint Mistral replaced both thermistors now what
    Update on this i left the fast freeze on overnight to see if it helped any but nothing so have just removed the bottom back panel and the tank is hot to touch but i can hold my hand on it just and no noise from it and also the fan is not moving.
  1. Hotpoint Mistral Plus - Fridge Freezer
    By cozzie121 in forum Domestic
    Last Post: 19-09-2010, 08:45 AM
  2. Replies: 2
    Last Post: 09-06-2010, 05:05 PM
  3. Hotpoint Mistral Thermistor Problems
    By ukcommando in forum Domestic
    Last Post: 23-02-2010, 06:20 PM
  4. Hotpoint Mistral Plus 8596P
    By mysterymistral in forum Domestic
    Last Post: 25-01-2010, 08:13 PM
  5. Hotpoint Mistral Plus
    By Bobby Ewing in forum Domestic
    Last Post: 05-01-2008, 11:35 AM
