Thread: carrier Supra 850 MT Please help
28-07-2010, 03:06 PM #1
I am trying to get an electrical diagram for the unit on one of our trucks.
The electric motor is free but will not run and keeps tripping the breaker.
Any help appreciated.
Thanks.
mike
28-07-2010, 09:05 PM #2
Re: carrier Supra 850 MT Please help
Why do you need an electrical diagram for that?
Just meter the motor out to check it is OK?
28-07-2010, 09:05 PM #3
08-08-2010, 01:37 PM #4
have u checked the over load setting in the control box ? also is it tripping out due to the engine clutch trying to crank at same time due to a seized on clutch ?
13-08-2010, 10:45 PM #5
Have you got 3 phases to motor? If not is the contactor and overload OK? I have had a few problems with Carrier contactors. Have you megger tested motor? If it all checks out Ok from memory I think there is a motor klixon in the circuit I have had problems with before.
13-08-2010, 11:02 PM #6
Carrier Supra 444
By ddocwra in forum TransportReplies: 14Last Post: 30-04-2010, 06:52 AM -
Carrier Supra 944 help please.
By georgiajimbo in forum TransportReplies: 5Last Post: 06-10-2009, 02:21 PM -
Carrier Supra 650
By Jwatdtr1878 in forum Trouble ShootingReplies: 0Last Post: 26-06-2009, 12:44 PM -
Carrier Supra
By Vernon in forum TransportReplies: 6Last Post: 05-07-2008, 07:39 AM
