Thread: Difference
26-07-2010, 08:24 AM #1
Difference
What are the advantages of scroll compressor over reciprocating compressor in split type AC system?
If we think both short time & long time basis.......
26-07-2010, 10:00 AM #2
Re: Difference
Interms of reliability and efficiency scroll has edge over recip. However the initial cost of scroll is higher,also recip can be repaired after the failure.
27-07-2010, 04:28 AM #3
27-07-2010, 06:55 AM #4
Re: Difference
The advantage for the manufacturer is mainly the price, a scroll is cheaper although most small splits till 7 kW have a rotary compressor. They say a scroll is also more silent.
difference between a normal air conditioner and ice cream maker refrigeration
By serenityjun in forum FundamentalsReplies: 9Last Post: 02-04-2010, 12:22 PM -
Difference of the DX and CW system.
By steven86 in forum FundamentalsReplies: 7Last Post: 07-03-2010, 09:11 AM -
The difference between an EPR valve and a CPR valve?
By kengineering in forum Technical DiscussionsReplies: 7Last Post: 05-02-2010, 07:47 AM -
pressure difference in TXV system
By david2008 in forum FundamentalsReplies: 13Last Post: 24-07-2008, 12:25 AM -
Difference between geo thermal and air to air
By ianybeany in forum Heat PumpsReplies: 5Last Post: 23-02-2008, 11:15 PM
