Thread: Sanyo VRV
    May 2010
    portugal
    44
    29
    Sanyo VRV
    Hello guys, i need your help here.
    I have a sanyo vrv unit
    outside unit model - SPW-CR903GVH8
    inside - RCS-SH80TG
    and with this unit i have a weird problem, 5 inside units, 3 of them ok, with 2 others something weird happens, they just turn them self on, always in cooling mode, tried to reset the controller, checked for timers, all ok.
    can any of u guys have the service manual for these units ?
    regards,
    Jul 2009
    stoke on trent
    48
    Re: Sanyo VRV
    maybe you have a centralized controller somewhere? or a scheduled timer ?
    Jul 2005
    Ireland
    164
    Re: Sanyo VRV
    Hey Kad
    Strange this should not happen unless as reg say's you have a central control device or are connected to an optional plug on the indoor PCB
    Can you give some more info.
    Check if any optional wiring is connected to the indoor unts PCB
    Are the three units controlled off the same remote??
    If there is a central control device and you can't find or access it try deleting the indoor units central address
    This will stop it getting an on command from a timer or central control de.vice
    Pres the test/chk set and Clr buttons for 4 seconds
    use temp arrows to go down to code 3 after display changes.
    Use the clock buttons to change the value of code 3 to 0099 then press set button.
    If necessary press the unit button to access the next connected indoor unit and repeat he process.
    Press test/chk to get out of this engineers mode.
    Let me know if this helps if not get back to me with more info.
  1. Sanyo anytime online training and stuff
    By King of VRF in forum Air Conditioning
    Last Post: 02-02-2010, 06:21 AM
  2. Sanyo fault codes
    By Slim R410a in forum Air Conditioning
    Last Post: 03-11-2008, 08:02 PM
  3. sanyo
    By cooltools in forum Commissioning
    Last Post: 27-10-2008, 07:40 PM
  4. Sanyo system needs supplemental heat
    By mchild in forum Air Conditioning
    Last Post: 29-11-2007, 02:50 PM
  5. fault on a sanyo unit
    By marc5180 in forum Air Conditioning
    Last Post: 18-08-2007, 11:04 PM
