Thread: Remote Thermostat.
24-07-2010, 06:17 AM #1
Remote Thermostat.
I have a Daiken FVXT50GV1NB Consol heat pump. It cycles fairly rapidly on and off, At the moment 15seconds on and 5 minutes off This maybe because it's location is close to a low shelf which does not allow the heat to get away from the built in thermostat quickly enough. I am thinking of installing a remote thermostat in a location which will allow a better temperature sensing. I have looked at programmable t/stats and wonder if they can be wired in to my indoor unit. We only need the heating cycle to be controlled.
14-10-2010, 07:49 PM #2
Re: Remote Thermostat.
hi lemuzz , on a ducted heat pump the temp, sensor would be in the return duct, but on a split heat pump, one would have to position the sensor at the side of the indoor unit < not touching <
or go back top basics and knock the lower shelf down
14-10-2010, 08:06 PM #3
Do you have a hand held or hard wired remote controller?
With some hard wired models you can select to use the temperature sensor within the controller instead of the unit.
I don't know whether that facility is available with the hand held units.Brian - Newton Abbot, Devon, UK
carrier splt sometimes doesn't respond to remote.
By paul_h in forum Air ConditioningReplies: 10Last Post: 14-02-2009, 05:44 AM -
Daikin remote thermostat
By Andy AC in forum Air ConditioningReplies: 4Last Post: 02-03-2008, 12:05 PM -
Remote Control problem
By botrous in forum Air ConditioningReplies: 2Last Post: 12-10-2005, 05:36 PM
