Results 1 to 9 of 9
    Cold Timer's Avatar
    Cold Timer Guest
    New industrial compressors
    I have a couple applications and am looking for the latest and greatest compressors available for an NH3 application. I have heard that Mycom has a new J Type screw compressor and a new M Type recipricating compressor and I have literature heading my way. Does anybody have feedback in regards to Mycom compressors?
    3,355
    Re: New industrial compressors
    Cold Timer ,
    Mycom are in general extremely good & simple compressors .
    But series you suggest I can't say .
    Have heard of valve problems in M comps but maybe its rectified now .
    Jan 2010
    Christchurch
    54
    28
    I used to rebuild mycoms and in my opinion they are one of the best if not the best compressor to work on, how often has anybody out there had to adjust the discharge end clearance on a mycom screw?, me never, the gaskets are precise (they are constantly the same thickness) and the parts machining is top notch (thrust bearing width).
    rkrummel's Avatar
    rkrummel Guest
    I had Mycom recip compressors at the plant I worked at 15 yrs ago and by far the easiest to maintain and rebuild (which wasn't too often) VERY reliable units. They were in a propane service. I have Carrier now at the plant Im at now pffffft I wish I had Mycoms lol.
    Jun 2010
    Russian Federation
    47
    For industrial application ,very good Howden screw compresors.
    Mar 2010
    Dammam
    83
    15
    Mycom screws are better than Howden in ammonia applications.
    Howden consumes a lot of oil and the mech'l. seal including that of the oil pump leaks in less than 10k running hrs.
    <"No one is so smart, they just stay with problems longer and use their imagination">
    Somerset
    69
    4,698
    Quote Originally Posted by ref717 View Post
    Maybe the ones you have experience with have.
    But I can think of plenty that don't have these issues.
    The Howdens I have worked with I have been impressed with.
    It is wrong to be so harsh to any manufacturer and no I don't work for them.
    Now to say you have had issues is fair.
    For instance to say "they consume a lot of oil".
    Any Comp will if it is not set up,or maintained correctly.
    Most engineers ( myself included) have favourites,
    Usually those makes that they know best!
    I tend to favour Sabroe, J&E Halls and Grasso.
    Cold Timer's Avatar
    Cold Timer Guest
    I appreciate the input
    Auckland
    74
    3,357
    37
    I would definitely recommend Mycom, check with Mycom USA web site.
    I agree with Grizzly that Howdens are very reliable if applied correcty, Howdens are bullet proof, simple to work on.
    It come down to product support and parts availability, and of course pricing.
  1. Troubleshooting 12 volt Danfoss BD compressors.
    By RLK in forum Trouble Shooting
    Last Post: 01-07-2010, 11:14 PM
  2. Compressors - screw or reciprocating?
    By Josip in forum Industrial Compressors
    Last Post: 27-01-2009, 10:36 PM
  3. FES screw compressors
    By negmy13 in forum Technical Speculations
    Last Post: 08-08-2008, 07:40 AM
  4. New types of Refrigeration Compressors
    By adjohnson208 in forum New Technologies
    Last Post: 03-07-2008, 07:35 PM
  5. Do we have some expert in replacing compressors
    By Zahid in forum Air Conditioning
    Last Post: 01-07-2008, 07:59 AM
