Results 1 to 8 of 8
    jazzy's Avatar
    jazzy Guest
    Beko Frost Free Fridge/Freezer - Electrical Smell
    Problem with my Beko Fridge/Freezer Frost Free Model CGA 9756 FFW
    There is a strong electrical smell which occurs every few weeks' may be something to do with the frost free system? I have noticed that the smell occurs when the back panel has water droplets and not ice.
    Also two holes have appeared at the back of the fridge compartment. (pic) img28.imageshack.us/img28/5170/beko.jpg
    any ideas please?
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    Re: Beko Frost Free Fridge/Freezer - Electrical Smell
    Hi Jazzy, Does the fridge ever tripout the circuit breaker or earth leakage to your place?
    jazzy's Avatar
    jazzy Guest
    Quote Originally Posted by mikeref View Post
    no never had issues with any tripouts. The temp also keeps constant all of the time.
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    Hi Jazzy, cannot bring up your pic, but i'd need to see these holes you talked about.
    jazzy's Avatar
    jazzy Guest
    to view the photo you will have to do a copy and paste
    unfortunately I cannot add photos to the forum because I do not have enough posts
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    Jazzy, visual on your pic didn't work on my side. If your fridge appears to still be working fine( no ice building up anywhere) than (1) its possible the defrost element in the freezer section has shifted too close to plastic surroundings causing a burning smell or(2) an insulated heater wire surrounding the fridge section evaporator may be faulty, either way you should get it professionally seen to, cheers mike.
    Auckland
    74
    3,357
    37
    Definitly have it looked at. You have the potential for a house fire, usually when asleep.
    Electricity, [heat source ] oxygen and foam [ insulation,]. Can start as a hot spot and develop into an inferno in 30 seconds. Do you have smoke alarms.
    magoo
    So dump the fridge and start again.
    jazzy's Avatar
    jazzy Guest
    Fridge/Freezer now scrapped, better safe than sorry
  1. Beko Frost Free - Freezing!!
    By JonFreezer in forum Domestic
    Last Post: 11-07-2010, 10:11 PM
  2. Beko Frost Free Fridge Freezer failing to cool
    By Derek Max in forum Trouble Shooting
    Last Post: 19-06-2009, 07:31 PM
  3. Replies: 2
    Last Post: 12-10-2008, 09:41 AM
  4. Beko frost free freezer/fridge help needed
    By DJT in forum Trouble Shooting
    Last Post: 22-12-2007, 12:13 AM
  5. Frost free fridge/freezer
    By aircon in forum Domestic
    Last Post: 21-05-2005, 09:44 PM
