Thread: addvent fault codes
21-07-2010, 10:00 PM #1
addvent fault codes
I have had the misfortune to have been called to be called to an Addvent AVAC SPL18-N split system that had been supplied and installed by a nameless electrician - Why do they never have names?
System goes out on E3 fault, reset power, and away it goes. When I got to it, found the filters blocked solid and the fan motor making a terrible racket. Because of the noise, the electrician had somehow managed to get a replacement indoor unit, which was never fitted. I swapped the fan motor and cleaned the filters, put it back together and ran fine for about a week, and is now faulting on E3 again. Anybody know what that code is?
I thought it could be shutting down on the evap coil sensor because of the blocked filters. Haven't been able to check pressures yet - condenser is located up high, in an alleyway, which is only accessible by going through a little old lady's house, if she is up and dressed. The indoor unit cools well, does not frost up, plenty of moisture all over the coil, but no ice.
I know the next thing to do is check the pressures, but was hoping it's something on the indoor unit because of the access issue.
Any suggestions welcome.
Andy
21-07-2010, 11:04 PM #2
Re: addvent fault codes
Is it from these people?
http://www.addvent.co.uk/
Couldn't find anything on their site though, might be worth giving them a call and see.
21-07-2010, 11:06 PM #3
yep thats them, I'll give em a call in the morning
carrier fault codes
By richelli in forum Trouble ShootingReplies: 5Last Post: 18-06-2010, 07:35 AM -
Sanyo fault codes
By climacool in forum Trouble ShootingReplies: 5Last Post: 31-01-2009, 01:27 AM -
Daikin fault codes
By Markie in forum Air ConditioningReplies: 16Last Post: 13-01-2009, 01:58 AM -
standardisation of fault codes?
By kelvin kline in forum Air ConditioningReplies: 1Last Post: 10-10-2007, 12:30 AM -
MHI, Sanyo & Fuijitsu Complete Fault Codes
By aeb200 in forum Air ConditioningReplies: 1Last Post: 16-11-2005, 01:11 PM
