Results 1 to 2 of 2
21-07-2010, 11:21 AM #1
Hotpoint fridge freezer model no ff200ep
After 18 months and out of warranty ice formed on the inside bottom of my fridge/freezer and each morning I came down to a puddle of water under the f/f.
I contacted Hotpoint who told me they charge £100+ call out etc. I checked this forum and discovered others had the same problem.
I then decided to try and fix the problem myself, I unscrewed the inside back and discovered another panel which held the fan, this I removed VERY CAREFULLY as the fan and wires are connected.
The drain which takes the water away was blocked with polystyrene and bits of metal also ice. I unblocked this hole and the water began flowing into the tray behind the back of f/f.
Is this blockage a ploy to get us to call out Hotpoint engineers and pay over the top call out charges.
Hope this helps others out there who have had the same problems
01-08-2010, 09:06 PM #2
Re: Hotpoint fridge freezer model no ff200ep
thanks for the info madge, well done
Hotpoint FF200E Fridge Freezer Fault
By fredalfred in forum DomesticReplies: 107Last Post: 29-12-2012, 01:26 PM -
Hotpoint Mistral Plus - Fridge Freezer
By cozzie121 in forum DomesticReplies: 9Last Post: 19-09-2010, 08:45 AM -
Hotpoint Fridge Freezer Model 8595 (frost free) Freezer ok but fridge not working
By rabb5it in forum DomesticReplies: 2Last Post: 08-01-2010, 11:41 AM -
Hotpoint FF200E Fridge Freezer Problem
By Gray73 in forum DomesticReplies: 0Last Post: 05-12-2009, 10:21 AM -
Hotpoint FFA71 Freezer High Temp Light / Fridge is Freezing
By sumnerpa in forum Trouble ShootingReplies: 1Last Post: 19-08-2008, 03:16 PM
