Results 1 to 9 of 9
    Jul 2010
    UAE
    14
    Smile Thermal Storage Tank
    Hi Guys,
    Can any body help me how to design a Thermal Storage Tank and what to consider on the installation.
    11,025
    Re: Thermal Storage Tank
    I would start with Google and work out from there.
    Here's a start...
    http://www.plumbingpages.com/feature...Thermstore.cfm
    Jul 2010
    UAE
    14
    Hi Brain,
    Thanks for the link actually I forgot to mention that I need thermal storage tank for the chilled water.
    Oct 2003
    5,630
    34
    www.cristopia.com the use balls filled with an eutectic solution
    And
    http://www.packo.com/en/5841 in the same street as we live .
    Aug 2007
    Sydney
    52
    1,083
    23
    Mathematically calculus maxima minima will allow you to work out the maximum volume with minimum surface area to give the least losses eg a cylinder calculates height of 2 with diameter of 1 roughly. Then baffling - a spiral vertical form where (stored) fluid travels on top from centre to exterior. This is for cooling - opposite for heating. I have not seen commercial units like this but you said you want to design one. So here's a start regarding the geometrical form, as for the heat xfer calcs you will find them on a search of this forum.
    Aug 2001
    Sweden
    47
    Quote Originally Posted by Tesla View Post
    There are some applications with Phase Change Material to reduce size. But PCM is not cheap
    Oct 2003
    5,630
    34
    A salt solution is a PCM and is well suited for a cooling application.
    don't try to re-invent the wheel and learn how others have made it.
    We once did a test with PET bottles from Cola filled with a salt solution and stored those in an isolated container.
    This worked very well. It's a little bit like the Cristopia system...but a lot cheaper.
    azka's Avatar
    azka Guest
    Hi forumers, i got another question about thermal storage tank. how to know about charging operation for storage system. how long to take time. what the suggestion to improve the thermal storage to keep energy for along time ?
    Oct 2003
    5,630
    34
    Time needed = time it takes to change the eutectic solution from its liquid to its solid phase + heat losses.
    Improve storage time = bigger tank is the only solution
  1. Thermal Sink / storage
    By dhananjaylagwan in forum Air Conditioning
    Last Post: 29-07-2008, 08:41 AM
  2. Thermal Storage Calculation
    By lana in forum Fundamentals
    Last Post: 04-07-2008, 06:31 AM
  3. Thermal storage system
    By Rajkumar in forum Air Conditioning
    Last Post: 13-06-2008, 06:10 AM
  4. chilled water storage tank!
    By dchatta in forum Technical Discussions
    Last Post: 24-05-2004, 04:23 PM
