Thread: RS44 R424a in City Multi
20-07-2010, 05:25 PM #1
Hi lads, Anyone know of any difficulties in dropping R424a into a city multi that used to run on R22?
Have a compressor failure and if the gas is compromised i might look at changing it as replacement R22 will only be a temporary solution. I've read up about R424a and found no negatives except maybe having to make a few tweaks and adjustments to the system. Any ideas how a city multi system would take it? thanks
20-07-2010, 07:54 PM #2
Re: RS44 R424a in City Multi
22-07-2010, 05:56 PM #3
Oh yeah, i know, you can still get plenty of cleaned up R22 over here too and its a hefty price, Im just exploring the options, because if the gas has been contaminated from the burn out then id much rather use the opportunity to fill the system with a drop in rather than more R22 as its going to have to go at some point, now is as good a time as any.
Daikin VRV vs. Mitsubishi Multi City
By Gabriel Gagnon in forum Technical DiscussionsReplies: 19Last Post: 15-02-2011, 06:12 PM -
City Multi Undersized
By MOVHVAC in forum Air ConditioningReplies: 3Last Post: 20-07-2010, 06:46 PM -
City Multi Faults
By Collie in forum Air ConditioningReplies: 2Last Post: 22-06-2010, 06:13 PM -
multi city error code 1102
By sork in forum Air ConditioningReplies: 20Last Post: 02-01-2010, 04:23 PM -
Need input on City Multi
By TDfromNY in forum Air ConditioningReplies: 4Last Post: 09-06-2006, 03:31 AM
