Thread: screw compressor failure
20-07-2010, 06:35 AM #1
what is the percenatge rate of failure of screw compressor?
we have a screw compressor that was working under 73% load with 9.3 C suction super heat , is it a propable reason of failure
20-07-2010, 09:09 AM #2
Re: screw compressor failure
Maybe 1%-5% if still in time life (10 years +/-), and if the refrigeration circuit is working fine. Also electrical part is very important, always garantee that you have 400V +-10% (or 600inEUA) and had a good manteinance to contactors.
The information you give is very vague its impossible to expect something. 9,3ºC is a normal SH.
What kind of failure it had? electrical or mechanical?
20-07-2010, 09:24 AM #3
if that is a low temp compresor 9.3 although a little lower is still ok.refrigeration load is ok.maintaining a normal life span of a compresor wheather reciprocating or screw involves preventive works on mechanical and electrical side of the system.
20-07-2010, 11:08 AM #4
25-07-2010, 09:58 PM #5
nice
should be learn/
30-07-2010, 06:09 PM #6
The rate of failure of any compressor is directly proportional to the design of the system and the technician working on the system!
What is the suction/discharge pressure/temperature? What type of refrigerant? What type of application?
If we can get information, we can start helping.I am not always right, but I'm never wrong!
VSD on screw machines
By Mike Hopkins in forum New TechnologiesReplies: 14Last Post: 20-02-2011, 12:10 AM -
R22 - R417 (RetroFit) Screw set A.C
By Chris_Atlantic in forum Trouble ShootingReplies: 3Last Post: 23-04-2010, 06:53 PM -
Compressors - screw or reciprocating?
By Josip in forum Industrial CompressorsReplies: 18Last Post: 27-01-2009, 10:36 PM -
advantage of twin screw compressor over single screw compressor
By azzah in forum New to REReplies: 7Last Post: 23-09-2008, 09:24 AM -
Mono or twin screw
By Nirmalya in forum Industrial CompressorsReplies: 43Last Post: 12-09-2006, 03:19 AM
