Thread: Split Blockages
Threaded View
08-06-2006, 04:19 PM #7
Re: Split Blockages
Mabe you need to recover the gas add test points on the indoor coil and might as well add a sight glass and filter dryer to catch crap and water in the system before it blocks the expansion valve. Does it have a capilery line in the outdoor unit to meter the liquid as well? if so this could be getting blocked by ice.
Pressure testing for leaks on split a/c systems
By mrchatts in forum Air ConditioningReplies: 46Last Post: 08-04-2010, 10:02 AM -
panasonic 3 phase split
By mike live in forum Air ConditioningReplies: 18Last Post: 18-08-2006, 11:54 PM -
can a r22 split system condensing unit be used to cool a display fridge
By tsangep in forum RefrigerantsReplies: 8Last Post: 20-05-2006, 04:21 PM -
Cooling condenser of split with condensate from evaporator
By smileypete in forum Air ConditioningReplies: 11Last Post: 10-07-2005, 08:21 AM -
LG ducted split
By Abe in forum Air ConditioningReplies: 20Last Post: 08-06-2005, 07:19 PM
