    bjennibblue's Avatar
    bjennibblue Guest
    Unhappy panasonic inverter HKR air con timer light
    My aircon is displaying a flashing timer light and will not turn on, i turned the power off to it at the power box and tuned it back on and the light was off but when i tried to turn it on again with the remote it satarted as usual but within 2 seconds the vents shut and the power light turned off and the blinking timer light began flashing again,i repeated the steps again but the same thing happened.
    Any suggestions please...... female, single, blonde but not entirely useless!
    bjennibblue Guest
    Re: panasonic inverter HKR air con timer light
    Quote Originally Posted by bjennibblue View Post
    I just looked up the manual and followed the instructions to get an error codeand it gave me H00 looked that up and came up with something to do with circuit?
    Jul 2007
    Australia
    44
    1,857
    14
    you have to scroll through all the codes by pressing the up/down buttons IIRC and see which code makes the beeps.
    How old is the unit? Do you have a receipt?
    It normally needs a proper repair rather than reseting something when you get error codes, so you will probably need to contact a pana service centre. If it's under 5yr old and you have receipt, should be under warranty unless rodent damage or something.
  1. Replies: 1
    Last Post: 18-02-2010, 02:29 PM
  2. asya12lcc blinking timer light?
    By nathancroweuk in forum Air Conditioning
    Last Post: 02-02-2010, 08:21 PM
  3. Panasonic inverter -Power factor protection
    By Blackbird in forum Air Conditioning
    Last Post: 28-06-2008, 01:17 PM
  4. How many forum posters does it take to change a light bulb....
    By taz24 in forum Chit Chat & Service Stories
    Last Post: 04-02-2008, 07:05 AM
  5. Panasonic air-con inverter unit
    By Baron in Spain in forum Air Conditioning
    Last Post: 04-12-2007, 11:34 AM
