Results 51 to 54 of 54
04-11-2010, 08:21 AM #51
Re: Trane Chiller: Noisy Oil Separator
at my problem, oil was completely going to the evaporator and there was a pipe 1/4" was comming from evap to compressor. also there is a small filter on this line. Oil filter was dirty and this small filter was dirty. so oil was not turning back to the separator and separotor was completely empty.
ur situation is different, because u have oil in separator. is there any mesh? did u see anything in the drier filter? or in the oil filter?
09-11-2010, 10:27 PM #52
I use to work on these alot and trying to get my memory together, make sure all the service valves for oil flow are open. From memory if one service is closed it will restrict oil flow and cause the bearing to whine loud. When checking oil level, make sure all valves are open and there is no ***** pressure boiling off differential in the system. Let the oil level stablize in your ***** hose sight glass for 15 minutes. If you are for sure there is the right amount volume of oil, then my very last thought is the centrifugal baffles are loose.
16-11-2010, 08:28 AM #53
Thanks to all of you for your most valued suggestions
24-11-2010, 04:00 PM #54
Question:
the machine's use to brine or comfort?
Trane chiller problem
By dannycool in forum Air ConditioningReplies: 6Last Post: 08-04-2010, 11:31 PM -
Trane chiller
By Lman in forum Trouble ShootingReplies: 4Last Post: 13-11-2009, 03:51 PM -
AEC Pinical chiller with trane comp
By cptrdbrd in forum CommercialReplies: 1Last Post: 28-10-2009, 09:47 PM -
Trane CVHE 450 R11 Centrifugal Chiller
By albertjoseph in forum Air ConditioningReplies: 4Last Post: 06-10-2008, 03:23 PM -
Connecting Trane Water chiller to air handling unit
By celtictech in forum FundamentalsReplies: 10Last Post: 08-03-2007, 06:14 PM
