Thread: Urgent!!!
    kfircohen59's Avatar
    kfircohen59 Guest
    Exclamation
    Hello to all
    Most urgent!!! I need service manual for clivet chillers wrat 292
    Somerset
    69
    4,698
    Re: Urgent!!!
    Even if I had the Manual you are after, I would not give it to you.
    As your multiple posts are Rude and arrogant.
    As you have not even bothered to read (Or observe) as to how to use the forum.
    1 post at a time is all that is required.
    The rest is just ignorance!!
    kfircohen59 Guest
    Re: Urgent!!!
    I did this because and I did not received an answer yesterday and because and the problem is urgent, I didn't know that I commits/transits legal the forum and regrets that angered you.
    Somerset
    69
    4,698
    Re: Urgent!!!
    Good answer.
    You won't be the last to multiple post!
    But if you think about the huge numbers of posters using the forum.
    If everyone did so the system would overload quickly, would it not?
    Have you considered that no-one can help. In the timescale you require.
    Manuals from some manufacturers are very hard to come by.
    What is your actual problem!
    Maybe someone can Help from Experience or Memory?
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: Urgent!!!
    Typical arrogance and bullish behaviour.
    I'm sending you the manual along with a cargo full of humanitarian helps.
  1. Replies: 12
    Last Post: 26-06-2009, 07:52 PM
