17-07-2010, 03:43 AM #1
HELP !!! Compressor Screwtype Model XJF151L
Help! me please , Why the "FRICK" compressor screwtype model XJF151L can't unload by manaul or automatic?
17-07-2010, 02:08 PM #2
Re: HELP !!! Compressor Screwtype Model XJF151L
Check your unload solenoid valve, is it working or NOT?
If YES, Checking oil pressure pressing on Unload piston
18-07-2010, 04:23 AM #3
Maybe some reasons, check the solenoid valve and must be sure in sealing ring of the capacity piston.
20-07-2010, 11:15 AM #4
check for blown fuse at output module. check for a bad unload solenoid coil, wiring or a faulty output module.
Compressor Model
By mjpaolo in forum Technical SpeculationsReplies: 2Last Post: 26-06-2009, 03:14 AM -
Model to Manufacturer Identification
By Lucas in forum Air ConditioningReplies: 5Last Post: 29-04-2009, 03:25 PM -
Fan model for system optimization
By autt in forum System OptimizationReplies: 8Last Post: 31-03-2007, 05:34 AM -
Daikin Model
By Geofridgee in forum Air ConditioningReplies: 1Last Post: 12-07-2006, 09:23 AM -
UK TV Show looking for model makers / engineers
By roadshow in forum HobbiesReplies: 1Last Post: 30-12-2003, 03:16 PM
