Thread: LG Fridge Freezer ( Warm Fridge)
16-07-2010, 07:51 AM #1
we have a LG GM-818 DTC, in which the freezer fan is not working, hence the fridge is warm, please, does anyone have circuit diagram for this model FF? or any suggestions.
Norman
20-07-2010, 01:05 PM #2
Re: LG Fridge Freezer ( Warm Fridge)
if the fan has a quick disconnect open it and give power directly to the fan from an outlet w/ 220 or 115v witchever the case might be if the fan works its not the fan might be the circut board or a sensor.Good luck!
20-07-2010, 01:24 PM #3
^ some fans are DC, though I don't know enough about LG to say, just a precaution to take.
The obvious though is i) the fan isn't running because it's in a block of ice, ii) the system is stuck in defrost mode.
Other than that, it's down to the fridge's diagnostic mode to check for a fan fault, or checking the PCB output voltage to the fan for a PCB fault.
24-07-2010, 07:44 PM #4
Having similiar problem. Kenmore side by side. Freezer cold. Fridge warm. Defrosted everything and worked fine for a week. Now back to cold freezer warm fridge. Fan did work after defrost.
fridge warm freezer cold?
By babsnsarah in forum DomesticReplies: 25Last Post: 30-04-2011, 04:24 PM -
Freezer OK, Fridge Warm?
By Liassic in forum DomesticReplies: 9Last Post: 28-11-2009, 05:43 PM -
Zanussi ZNB 3850 Fridge warm, freezer cold
By thenotts in forum DomesticReplies: 2Last Post: 02-11-2009, 10:05 PM -
Indesit FROST FREE Fridge Freezer - fridge not cold
By pauby in forum DomesticReplies: 26Last Post: 09-03-2009, 11:04 AM -
Belling Fridge warm, Freezer cold, please help.
By beuwy in forum Technical DiscussionsReplies: 0Last Post: 04-03-2009, 01:42 PM
