Thread: Hotpoint FFS70 Frdge freezing up
16-07-2010, 07:13 AM #1
The back panel plasctic of the fridge unit is covered in ice and the temperature is at or below freezing. The thermostat control does not appear to have any effect. Freezer seems unaffected. Any ideas? It hasn't been switched off for ?years? and I've never used the "holiday" button.
Adrian
16-07-2010, 10:35 PM #2
Re: Hotpoint FFS70 Frdge freezing up
is it freezing all over equally of thicker ice at the top?????notice that the compressor is running constantly or more then normal?is the wall flat or bubbling out a bit(creases in the top corners)
19-07-2010, 07:36 AM #3
Seems to be pretty uniform ice - in droplet shape - over whole of back panel. Not too sure if comp. is running constantly, although we don't think so. The temperature adj. does not appear to have any effect either.
Thanks.
Hotpoint Mistral Plus - freezer temp intermittantly goes above freezing!
By robinsmh in forum DomesticReplies: 0Last Post: 22-10-2009, 01:31 PM -
Hotpoint FFS70 defrosting and high temp leds lit
By Aitcho in forum DomesticReplies: 13Last Post: 07-09-2008, 01:29 PM -
Hotpoint FFA71 Freezer High Temp Light / Fridge is Freezing
By sumnerpa in forum Trouble ShootingReplies: 1Last Post: 19-08-2008, 03:16 PM -
Hotpoint FFS70S noisey and now not freezing
By aragorn in forum DomesticReplies: 4Last Post: 24-03-2008, 07:09 PM -
Hotpoint FFA71 freezing problem
By pomodoro in forum DomesticReplies: 6Last Post: 06-01-2008, 08:10 PM
