Results 1 to 1 of 1
Thread: Pressure Relief - CO2 Booster
14-07-2010, 11:52 PM #1
Hi all
Booster CO2 transcritical for small retail - MT & HT Duty
Working pressure = 90bara (35`C GC out)
The Ps high side = 120Bara
The intermediate = 34 Bara (liquid @ -1`C)
LT evap @ -35`C
I have selected 120bar PRV high side, 40bar low side MT & 25Bar low side LT - & heres the crunch 90Bar on the receiver vessel (which is designed for 90Bar) .The compressor rack is all steel pipework & fittings rated @HP.
Now if the display cases are only rated at circa 40bar & copper pipework away from the pack in copper - how can you separate the design on the pack from the extraneous evaporators - & what happens in the event of standstill?
Your thoughts would be appreciated
BlakAdda (Don`t call me Edmund)
How to Design Refrigeration Systems
By US Iceman in forum FundamentalsReplies: 63Last Post: 24-07-2008, 04:27 PM -
High Deferential Oil Pressure Alarm
By NNNNNN in forum Trouble ShootingReplies: 27Last Post: 24-12-2007, 01:06 PM -
High pressure reading before and after condenser coil
By Cofreth in forum RefrigerantsReplies: 6Last Post: 18-11-2005, 04:30 PM -
over-under pressure relief valve
By philip de moor in forum IndustrialReplies: 3Last Post: 08-01-2004, 12:50 PM
