Thread: chilergy
14-07-2010, 07:45 PM #1
chilergy
Hello Chaps
New to forum and has anyone had any experiences with chilergy units (variable speed drives) fitted to compressor units
Good or bad remarks welcomed
Thanks for your replies in advance
14-07-2010, 09:24 PM #2
Re: chilergy
If you had done a search on the forum you would have found that this has been discussed before and the results are poor.
http://www.refrigeration-engineer.co...light=chilergy
I don't think that it has anything to do with variable speed drives, they don't say so.
It is a device to chop the peak power waves on the mains to reduce the energy charges which look at peak demand, I think.
Have something similar used in a school. Fine for the lighting but blew out three boiler burners costing thousands.
Unit has now been reconnected and separate power supplies brought in for the burners.
Read the other thread and go from there.Brian - Newton Abbot, Devon, UK
14-07-2010, 09:39 PM #3
Re: chilergy
Thanks Bri
New to forums in general!!!
The units have taken 8-10 evap motors out and also the equipment they are fitted to is varies from 6-12 years old. The post i have looked at would suggest that at this point still with the jury?
i.e no one knows much about it
20-07-2010, 03:50 PM #4
Re: chilergy
An interesting read and the website seems very vague. No idea what the cost is but given the new wave of pure energy saving motors i can't seem to see the need for this. But then i'm not on the front line so i imagine you engineers have a greater perspective than me on the subject.
Slightly going off topic would you agree that the whole "engery saving" and "being green" movement has started to gather pace?www.elco-motors.co.uk
06-08-2010, 07:05 AM #5
Re: chilergy
hi all,
i am an electric motor engineer/ Electrician of 20y, and also new to forums!!
i have fitted the single phase version of chilergy on to a refrig unit at a shop in Gloucester.
Current wise the unit was pulling 9a after fitted unit 6a. So it looks good so far......
i dont know how these things work but i assume they are trimming the re-active power of the motor.
ie: when the motor is not fully loaded the rotating magnetic field in the windings needs not be as strong thus reducing power consumed.
As for VSD`s, these (1ph) units units are v small and i would think that they are not.
Not fitted any 3ph yet.
very interesting forum
cheers
Rich
Chilergy ?????
By 123-steve909 in forum New TechnologiesReplies: 9Last Post: 05-03-2010, 03:57 AM
