    Jul 2002
    Derby
    74
    22
    Blast freezer question
    Hi all
    I wonder if someone could help me with the following question please:
    If i have a Blast Freezer which is a certain room size and I then increase the room size (say length), but the product load stays the same what would be the effect of this ?
    i am guessing my refrigeration duty of the kit would still be the same as the volume of air through the evap coil would be fixed by the fans, but the extra volume of air would reduce the air changes? if it was only the length of the room that was changed this wouldnt effect air speed?
    But how would this effect my reduction of product temperature ??
    any help or guidance welcome
    thankyou
    May 2008
    66
    802
    Re: Blast freezer question
    I think you have to look for what yore room was designd for in the first place.
    did it needed a specific temperatuur on a designd time? is yore product already in a slightly froozen state, ore is the room designd to freeze the product on a specific time?
    making changes to a coldroom or freezer is something that takes serius consideration before applying.
    Ice
    Jul 2002
    Derby
    74
    22
    thankyou for the response
    unfortunately i do not have that information, I only have the duty of the kit etc, and know that it will reduce the temperature of a certain amount of product in a time succesfully as it is doing it now, this product load weight and temps etc will not change but the size of the physical store will and im confused as to what effect this will have , obviously heat infiltration etc will be bigger but i would think this is very minor in comparision
    3,356
    As long as there are no short cuts of the air between product , above , around etc shoul be the same I think .
    Basically product should be packed as before .
    Jul 2002
    Derby
    74
    22
    thanks for reply
    If the room was wider and therefore cross section was larger i am guessing the velocity would reduce, so my other question is if i reduce the air speed over the product i would reduce the rate of heat removal ??
    Jul 2009
    Brisbane
    67
    79
    15
    Any extra bypass air will lengthen the freezing process. The extra size will increase the wall transmission load but if the size increase is small it should have little if any effect as the load of the product is generally a much higher percentage of the total load.
  1. Blast freezer addition
    By nanuuk in forum Technical Discussions
    Last Post: 08-04-2010, 03:49 PM
  2. Blast Freezer Within Freezer
    By rickmor in forum Technical Discussions
    Last Post: 18-06-2009, 03:37 AM
  3. Trolley freezer & blast freezer
    By smpsmp45 in forum NH3
    Last Post: 25-08-2007, 07:29 AM
  4. Blast Freezer
    By w.l.ong in forum Industrial
    Last Post: 16-12-2006, 10:34 AM
  5. Blast Freezer Questions
    By rickmor in forum Industrial
    Last Post: 11-04-2006, 08:15 PM
